installing lift ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wahbob, May 1, 2002.
  1. wahbob
    wahbob Registered Member
    Dec 27, 2001
    76
    Austin,Texas
    installing lift ?\'s
    I am installing my 4" rough country lift. Springs in front and blocks in the back(i know, i know). Anyway when some of you were installing your front springs did you have to remove the brake lines to install them? My axle doesnt seem to be down far enough for me to put the new ones on, the only way i see is to disconnect the lines because they are at their limit. If so how the hell do seperate it from the frame???? I took the clip off of the frontside of the frame---now what.?.??
    Thanks in advance,
    Mike B.
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Re: installing lift ?\'s
    remove the callipers. not the lines. this way you dont have to bleed them again.
    grant
  3. wahbob
    Dec 27, 2001
    76
    Austin,Texas
    Cool Thanks.
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Remove the calipers, but after the install, make sure that you have enough slack in your lines at full droop. If not, you may have to route them under the frame instead of through.
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    we didn't have to remove the lines on my friends sub to install his 4" procomp lift.
  6. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    I'm not suggesting removing the lines to install the lift. I am saying that you need to check them at full droop. If they are tight, you need to address that issue.
  7. wahbob
    Dec 27, 2001
    76
    Austin,Texas
    Thanks everyone for the quick reply.
    Much appreciated
