Installing Marine Style battery box.. pics inside
Discussion in 'The Garage' started by 78Suburban, May 18, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I'm installing the 50 dollar battery relocation kit from summit. it says its for marine or auto use. The instuctions are uber bootleg, their printer must have messed up, and you can't see the illustrations at all. I drilled the holes exactly like the template showed, and it lines the j hooks up wider than the box, so I'm assuming the j hooks are outside the box, and the h clamp is inside the box. The instuctions said if the battery is shorter than the box, cut the appropriate side piece of wood, so I guess I'm about to go look for some scraps and bust out my sawzall. I just don't get how the j hooks go outside the box, and the lid can still clap on?
    The kit also has some yellow nlyon strap to hold the box itself down.
    So can anybody tell me how this is all supposed to go together? The jhooks are kinda throwing me for a loop.
    Any ideas guys?
    thanks,
    James
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    the holes you drill i think should be in the bottom of the box. then the j hooks hook into the h piece, then through the holse you drilled and then throught the floor where you can place a washer and nut to them
    hmm. i think im wrong. doesnt look like the j bolts stay insed the box. isnt there a flared piece on the cover on both sides so it doesnt hit th ej bolts?
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
  4. 87350blaz
    87350blaz Registered Member
    Oct 23, 2005
    33
    New Mexico
    according to the instructions you did it right. Just need some ply wood underneath the battery to bring it snug to the H bracket.
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Well, the problem is that the lid isn't fitting over it, because the j bolts are outside the box. I dirlled the holes for the j bolts EXACTLY like the template showed
    Called summit, got some dude that sounded like he was on the crack rock. But he told me to drill the holes INSIDE the box. So I guess the template was incorrect
    I'm gonna go out and drill new holes through the box, and new holes narrower than the template said, so the j hooks will stay contained inside the box :mad:
  6. 87350blaz
    Oct 23, 2005
    33
    New Mexico
    it must be mandatory to have bad customer assistance these days
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Those boxes SUCK. I rolled my truck and the battery came crashing through the box:doah:
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    yeah, from the looks of the quality, they pretty much suck.. at least I'm mounting it far enough back that the battery probably won't hit my head :laugh:
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    i cant believe it was 50 bucks!
    i thought that it had to be on the inside. what idiots. lol
  10. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Hmm, checked out the PDF instructions, and from what I can tell, the hooks are outside the box. In the very last pic of the box on page 2, where they show the box with the lid strapped on, I *think* you can see te j-hook outside the box. Maybe you need to pound the lid on with a BFH!
  11. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    got er done
    Well I got it all wired up.. I did end up keeping the rods outside the box. And I made a big wood spacer under the battery. The little plastic pieces that screw to the floor to run the yellow strap through are pretty pathetic.. One of them broke when I screwed it down, but the J hooks seem to be doign the majority of the securing. I ran the positive wire inside the burb, untill I got the the front passenger floor, at which time I just ran it through the soft ball sized rust hole :doah: Overall I'm happy with the battery box, and hopefully I won't be flipping anytime soon.. maybe it'll hold up ok. I wish I could take pics, but its darlk now.
    thanks,
    James
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    What I used from Summit too.............
    I need to check tomorrow if that is corrosion, not supposed to leak.
  13. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I like the stuff from Blue Sea
    and these....
    Tracy also makes some nice stuff...
    I have certainly seen better in highend boats, but thats what the general population will find...
    Quite a few things people would find interesting from the marine world.. Especially electrical.... can't tell you how much better a quality marine grade tinned battery cable is over welding cable.. I see the evidence daily... Doesn't quite bend as nice initially, but outlasts it by about 5 times...
    Heck, my dash and console are a marine product....
  14. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hmm, I'm thinking big freaking ammo can for my 110 lb glass matt batt...
  15. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    Best use I found for one of those battery boxes was to strap in down in the rear of my suburban and fill it fulla tools....makes a great CHEAP tool box! I got mine for like 7.00 at Wal-Mart, but it did NOT include any wireing, just the box and the strap to hold it down...
