Installing new gears in 14BFF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Langosta39, Jan 16, 2003.
  1. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    When I install new gears should I buy an install kit? It about doubles the price of the new gears! Can I inspect my axle to determine this, what do I look for?
    Thanks,
    andy
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You'll probably need one since the bearings are hard to get off of the carrier without ruining them. Since you're going to hav the thing apart anyways it is a good idea to replace the rest of the bearings too, plus you get a new pinion seal and pinion nut, which should be replaced while you're there. You'll also you'll need shims to set up the gears. So what I'm trying to say is - yes, you need the install kit, and I recommend the Master kit with all of the bearings.</font color>
