Installing Reses hitch on 91 4x4 1\2 ton Suberban?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87sm465np208, Jun 21, 2003.
  1. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    Installing Reses hitch on 91 4x4 1\\2 ton Suberban?
    how do you get those bolts to stay put and accutally get them tight so you can tighten the nuts down? im really confused on this, please help /forums/images/graemlins/1zhelp.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  2. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Re: Installing Reses hitch on 91 4x4 1\\2 ton Suberban?
    My 91 sub has a 'weld-on' bumper hitch, so not 100% familiar with what you're trying to do, but from ones i've seen in the past (as well as recently putting a class II on mamma's van.......)... I use NEW hardware & sneak up on it!
    Well, sorta sneak up on it. If you can use new nuts/bolts/etc, I've had good luck with using an air wrench to zip 'em down. The rapid/hi-speed torque (what i call the sneaking up part) from the air has usually worked for me. /forums/images/graemlins/thumb.gif
    Another thing i've done when messing with those bolts is to try and angle 'em so there's resistance against the side of the bolt from the bolt hole.
    Guess as a last resort, you could weld it in place....
  3. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I don't know if the burb and blazer are the same but when I recently did mine on my 82 blazer the two front bolts came with a little piece of metal plate with a sqaure cut into it the bolts were carraige style bolts also that is how my set up the hard part was fishing them into the frame since the damn fuel tank is in the way....Jason /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/pimp1.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Some hitches come with nuts that have a piece of stiff wire welded to them. This lets you slip them into place up in the frame rail, when access is tight. /forums/images/graemlins/cool.gif BTW, I prefer to install the hitch with the bolts pointing up into the frame. It protects the threads from rock rash and such. /forums/images/graemlins/wink.gif
  5. woody9
    May 27, 2001
    602
    Howell, MI
    Harry (as always ??) brings up a good point about direction.
    Depending on your access to the backside.... (or if your nuts are wired?? /forums/images/graemlins/shocked.gif ), up is mo-betta!!!
    I think i've been a street lizard too long here in Wisconsin and need to get back to some real Wheelin' in Colorado!!!!!!!!!!!!!!!!! /forums/images/graemlins/thumb.gif
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I just droped the tank /forums/images/graemlins/rotfl.gif
    It was just 5 min and made the rest of the work too easy ended up taking much less time.
    /forums/images/graemlins/grin.gif
    And I do have a skid plate under the tank, still wasn't too bad.
  7. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    thanks guys, yea the 31 gallon gas tank is in the way hardcore, but i will try differnt ways to get around the gas tank to get the bolts in and get a wrench and hold them down, my hitch on my 87' shortbed was a sinch, the only hard part was holding the thing up there myself. /forums/images/graemlins/eek.gif.
