Installing shackle flip?
Discussion in 'The Garage' started by JUNIOR-K5, Jul 12, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    I will be installing a shackle flip from kert this weekend with a zero rate. My question is will I need a angle shim in the rear or will it be fine. It will be going on an 88 burb which currently has a 2" lift.
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    different tranny/tcase's will have different driveline lengths.. it really all depends upon alot of factors.. in general, burb's have a longer driveline, and are less likely to need to be shimmed. Shackle flips point the pinion up for you.
    In my case, I used an echobit shackle flip, and it would have been perfect for a shorter wheelbase rig, but it actually overcompensated, pointing the pinion up too high. I'm actually going to have get some shims and run them backwards from how most people run them with lift springs.
    Bottom line= Do what I'm going to do this week and get one of these bad boys http://www.lowes.com/lowes/lkn?action=productDetail&productId=198122-1099-AF006M
    you'll want your angles to be the same at either end of the shaft.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    On my '91 I had to use a 6* down angles zero to put the pinion and t/case at equal angles (you DON'T want them pointing at each other unless you run a cv rear shaft.). Then I went to a CV rear shaft and needed them 4* up to point the pinion directly at the t/case.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    My burb is fine with the QRD flip and a zero rate in the rear. No shims needed and the zero rate is flat.
  5. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Cool thanks guys I will install it this weekend and see how it goes.
