installing shims... one man job?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Oct 27, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    can i do it by my self? or will i need help? /forums/images/graemlins/confused.gif my best friend is working all the time and never has time to work on our trucks with me. /forums/images/graemlins/frown.gif
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Shims under the rear springs right? Yeah, You should beable to do it yourself no prob. /forums/images/graemlins/smile.gif
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    $12 hour x 8 hours = 96 dollars. This is side work that has a deadline and needs to be done. I can only do it on weekends and after work on weekdays. If I have a chance to make 100 dollars in a day, I am gonna work so I can afford to buy more things for my truck. I took time off work to help with your bodylift and I've never took off work to even be with my girlfriend, so don't think I don't want to help because I love to be there but I have priorities that need to be taken care of. I'll be done with this job soon so I can probably help sometime.
  4. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Everything on your truck is a one-man job. At least it is on my truck. You may need a little help with a "come-along" to re-align the rear-end with the springs, but you can do it by yourself.
    _____________________
  5. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I swapped both of my axles in 6 hours _by my self_.
    Even if you have to cut off the old u-bolts, it shouldnt take longer then a couple hours
  6. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I put add-a-leaves on my burb alone in about 5 hrs. That included the cussing at 13yr old dirt and finding fitting tools. /forums/images/graemlins/burb.gif
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I pulled my old 12b and swaped in the 14b bymyself in 2 hours and 15 minutews. Including bleeding brakes. /forums/images/graemlins/smile.gif
  8. muddysub
    Jun 23, 2001
    10,451
    489
    these are on the front.
    so i guess i'll do it this weekend.
  9. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    pretty easy, shouldn't take more than an hour(I'm thinking 20 minutes). Jack the spring (one side a time) or frame and let slack in the u-bolt...pop her in!
  10. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I would say you should have no problem putting in shims, when I was 17 I did my 4" lift by myself in about a little less than a day. /forums/images/graemlins/k5.gif
  11. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    20 minutes! That's funny. You should see how many 20 minute jobs I've started that ended up taking a six hours. Expect the unexpected with your truck.
