? installing shims
Discussion in 'The Garage' started by k5floyd, Jan 6, 2007.
  1. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    before i unbolt the axle from the springs does anyone know if the center pins on the stock 52" rear springs are long enough? if not where can i get longer ones? also i heard about using allen head bolts instead, anyone know what size i would need if i were to do that instead?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You need a 3/8" allen head bolt. The length depends on the thickness of your spring pac with shim. I buy my allen head bolts at Lowes.
    Ira
  3. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    gracias senior
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    My shim set came with (longer) bolts and a short piece of tube with the same OD as the bolt head. Pretty clever way to make a "deep head bolt".
    Tip; tape the shim to the spring pack while you wrestle the axle to line-up the hole.:D
