Installing tach...doesn't work?
Discussion in 'The Garage' started by stallion85, May 31, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Installing tach...doesn\'t work?
    I bought a new tach today and have everything hooked up and it is not working. I have a red, green, black, and white wire. The red is feed into the fuse box, the black ground, and the green is feed right to the distributor. The white is for light control. It is a suncraft or sunpro brand. The instructions state that you must have the power installed to a acc that only comes on in the run position. Not off or accessory. Does anyone know which one I could use?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Re: Installing tach...doesn\'t work?
    Did you hook the green wire to the negative side of the coil? For the time being just hook the red wire up to 12 volts and make sure you have a GOOD ground.
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    There is only one place to plug in the wire? It says tach above it??? How can I tell if the ground is good or bad?
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If you have an HEI ignition then the place that says TAC is the ocrrect place for the green wire, as far as a good ground make sure wherever you have it hooked up that there is no paint and that the metal is shiny new looking.
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Ok, I found it was a bad ground, thabks Scott /forums/images/graemlins/thumb.gifOne last thing where do I hook the light wire to?
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I hooked my white tach wire to the brown wire of the headlight switch /forums/images/graemlins/thumb.gif
  7. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    there are a few open ports way at the top of your fuse box. Some are hot with ignition, some with lights and some hot all the time. They are color coded and use a straight push in blade connection. Very easy to tap into and that is what they are there for. Take a test light and find out which one is hot with the head lights and plug er in.
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I attatched the white wire to the brown on the light switch and no luck. Could I just tap in behind the instrument lights and split off one of those wires?
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You can attach it to any wire that becomes hot when you turn the headlights on.
  10. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thanks, will do tomorrow. I've been busy this weekend and the wife is starting to get jealous of the truck /forums/images/graemlins/whistling.gif
