Installing tach without instuctions
Discussion in 'The Garage' started by bigredblzr, Sep 6, 2003.
  1. bigredblzr
    bigredblzr 1/2 ton status
    May 9, 2003
    151
    NORCAL BABY
    Yeah, I have a 91 K5 and it didn't come with a tach. My buddy gave me a tach, but he is a Jeep guy and on top of that moved away, so he wasn't any help on installing it. I realize that one of the wires runs to some sort of port on the distributer, but I removed my dist. cap and for some reason I couldn't find the connection. Can anybody tell me where it might be on a 91 K5? /forums/images/graemlins/confused.gif
    Thanks,
    Nate
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The port is usually the one marked "tach". /forums/images/graemlins/thumb.gif </font>
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    If its not marked "tach" then its the the connection that is not marked "tach" on the distributor cap. You do not have to take anything apart to connect it BTW.
  4. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    It is on the dist cap. It is the only open terminal on the cap and is right beside the big (usually red) ignition wire.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I think these guys are talking about the old style HEI with the coil in the cap.
    Your 91 should have the the remote coil.
    Look at the coil. You will see a connector on it with 4 wires. One of the wires is white and not hooked to anything. That is the wire you connect the pickup wire (green) fron the tach to.
    Most tachs are hooked up as follows
    Red - 12V+
    Black - 12V-
    Green - coil
    yellow and sometimes White - to dash lights
  6. bigredblzr
    May 9, 2003
    151
    NORCAL BABY
    Thank you sooo much Thunder, your reply was very helpful!
