Instrument clusters
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shawnboy, Jun 24, 2001.
  1. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Is there a stock tach setup for our trucks. I don't want to have an external mount and I think the tach would fit nicely where the gas gauge is and the empty hole on the bottom left would be a more suitable location for a gas gauge. Any suggestions?
    Shawnboy.
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Yes, there is a factory tach that fits in the gas gauge location......check ebay.....or LMC etc. You really need the whole cluster to do it right. Here's one now: http://www.jmartin.net/parker/goose.htm
    <P ID="edit"><FONT SIZE=-1>Edited by Michael on 06/24/01 09:15 AM (server time).</FONT></P>
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Yep, as Michael said, its a direct bolt in, as long as you get the entire gauge pod with the flexible circuit board.
    Pic of the factory tach cluster on my website below - click on interior page and scroll to the bottom.
    Easy conversion, hardest part is finding a reasonably priced tach cluster!
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.alloffroad.com>http://www.blazzinor.alloffroad.com</A>
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    or if you wanna go after market... it is a spendy way to go, but you get a programmable speedo that can be calibrated easily when ever you do a gear / tire change.
    if you are interested do a search on VDO about 3 months back and I have a list of part numbers and all that good stuff!
    http://www.vtengineering.com/ck5/dash-dark.jpg
    <A target="_blank" HREF=http://www.vtengineering.com/ck5/dash-back.jpg>http://www.vtengineering.com/ck5/dash-back.jpg</A>
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  5. SummitXMK
    SummitXMK 1/2 ton status
    Jun 6, 2001
    141
    Idaho
    Nice Interior BlazzinOR,
    On the cluster install are wires and sensors already in for the tach. I have a complete cluter from a Suburban that I was planning on doing pretty soon. If its a direct bolt on that would be great!!
    78 K5 Cheyenne 240K miles and counting (praying)
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    They are expensive and hard to find used, but I like having mine there. Beware when shopping used, they changed the font on the gauges in '77 ( I think). Mine is out of a '76, it's not a perfect match but I'm the only one who notices, I wasn't picky since I got it at a junkyard for $5. It's easy to make the tach and small fuel gauge fit in the standard gauge bezel, I wouldn't waste the money.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. BurbinOR
    5,829
    Oregon
    IF you get the gauge cluster and the pod that comes with it, it is a total bolt in. The gas gauge is the key..........have to have the correct flexible circuit board to make the connections correct. On the tach I wired it direct myself...........
  8. SummitXMK
    Jun 6, 2001
    141
    Idaho
    Do you wire the tach from the circuit board or the tach itself? Also how do you wire the tach to the moter? I have never wired a tach before but I am guessing from some of the other posts it goes on the distributer somewhere. Thanks for all the info.
  9. Michael
    1,576
    Sherman, Texas
    There is a terminal on the HEI distributor cap marked "Tach". It requires a .250 female spade to plug into it. I think the wire will go to the Tach...not the circuit board.
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  10. BurbinOR
    5,829
    Oregon
    Wired the tach independent of the circuit board. On an older HEI (like I assume you might have with a '78 K5) there is an ear sticking out of the HEI that has a TACH and a BAT terminal within it. Just plug the tach in there...........
  11. SummitXMK
    Jun 6, 2001
    141
    Idaho
    Thanks Guys!!
