Instrument panel dash lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scottnj, Jul 6, 2003.
  1. scottnj
    scottnj 1/2 ton status
    Aug 4, 2001
    112
    Central Florida
    Not that this is anything important but I thought I would share. The dash lights have always been dimmer then I liked in these model trucks and blazer/jimmy's.
    I have tried a few things but I found a perfect way and have been running it for over a week now.
    The 194 bulbs are about 2 to 3 watts each.
    I found out that the 3652 type bulbs are the same size but are 5 watts each. That makes the perfect difference. The heat is not any more that i have been able to tell.
    The auto parts stores sell these things for almost 6 bucks each.
    I found this place online
    http://www.automotive-lighting.com/mini_bulbs.asp
    They have the same exact bulb in 10 packs for 12.96 plus shipping.
    You need 5 for the dash lighting itself, one for the a/c controls, and one for your 4x4 lever.
    The other bulbs do not need to be changed.
    Hope this helps.
    Scott
    PS. The newer blazers(not sure when it started) has the bulbs soldered to the sockets. You can buy these sockets too but they are expensive. Go to the junk yard and grab a bunch. Many of the older cars and trucks used them.
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
  3. BXwildshot
    BXwildshot Registered Member
    Sep 17, 2001
    97
    Bronx , NY
    Get some 908 bulbs they are the same base but a bigger bulb and like 11 cp as opposed to the 5 cp of a 168 bulb.
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I always used brighter bulbs, it's definetly better. I got a white gauge face kit recently and I am gonna swap that in with blue back drop bulbs. that way it matches the CD player!
