Instrument panel question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blackwidowk5, Dec 14, 2000.
  1. blackwidowk5
    blackwidowk5 1/2 ton status
    Dec 1, 2000
    107
    Richmond, Virginia
    A couple of the lights in my dash are burned out, and i was wondering where the lights are located, and would buying a new instroment cluster work instead of replacing the lights? '79 Blazer.
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Why buy a new cluster? They are very expensive! If you change the cluster you'd have access to the light bulbs anyway.
    All you have to do is remove the screws that hold the cover, then the plastic lens come out, then you can access the little light bulbs. It's a bit tricky to remove everything because it gets stuck easily. A little patience is all it takes.
    Someone with small hands could also reach a few of them from behind. You just twist a small cap which comes out with the bulb.
    Hope this helps.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm pretty sure that you can reach all of the bulbs from behind the dash. You might have to drop the a-c plenum out of your way to reach them but there's no need to disassemble the cluster (and certainly no need to replace it!) [​IMG] The bulbs come out with just a quarter-turn.
    http://ThunderTruck.ColoradoK5.com
  4. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Cluster comes out easy enough, hardest thing is releasing the speedo cable. Don't use those aftermarket Chinese bulbs, they are crap. I always leave the wreaking yard with a pocket full of old GM bulbs that I pull from outfits while there, they seem to last the best. I always ware latex gloves while messing with insterment clusters, you don't want to leave your fingerprints there! They will be there for the next couple of owners.
  5. blackwidowk5
    Dec 1, 2000
    107
    Richmond, Virginia
    I appreciate the help. The reason i was think of replacing the whole panel was because i found one for 20 bucks, i thought that might be worth it just for the working clock.
    Jon
  6. Hobbes68
    Hobbes68 Registered Member
    Mar 20, 2000
    80
    Yonkers, NY
    For the clock it would be worth it... not just for the bulbs. Before you put it in, I'd change the bulbs with new ones anyway.
    If you don't want that other cluster, I'll take it off your hands. I always wanted a clock in my truck but it didn't come with one. It doesn't even look like I could add one without major fabrication.
