insulation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bennevis, Dec 19, 2000.
  1. bennevis
    bennevis Registered Member
    Mar 28, 2000
    41
    Colorado
    Just put in herculiner from front to rear this fall and now with the insulation out, its pretty cold. Any ideas on what to put in besides the unsulation and carpet I just pulled out? Also, for those of you with 33's what gears are you running?
    Thanks Bennevis
  2. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    I'm about to put down some armaflex and some carpet. This armaflex stuff looks sweet, it's a closed cell foam insulation, should hold the cold out fairly well. I'm putting down 1/2" thickness.
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    So it sounds like you don't want carpet??
    If you do then get that shinny stuff thats about 1/2 inch thick and put it under the carpet. I've seen it perrty cheap at Orchard Supply.
    I have 33" and run 3.73s, my 350 is sorta pumped and built for lowend torque. It does perrty good but I still dream about my 383Stroker i'll have some day/.........
    http://www.burt4x4.coloradok5.com
  4. bennevis
    Mar 28, 2000
    41
    Colorado
    What is armaflex? Can I put it over the herculiner and is it durable? Where could I get it?
    Bennevis
  5. bennevis
    Mar 28, 2000
    41
    Colorado
    Burt4x4, what is the name of the shiny stuff and can is it insulation or another kind of liner?
    Bennevis
  6. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    armaflex is basically that foam that you wrap around your pipes, except this stuff comes in rolls too. I just called an insulation store and it's $0.83 per sq ft for 1/2" thickness...
    -JoSH
    crazeebush@aol.com
  7. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    You could also buy some 3/4" rubber matting(like the stuff that people lay in the box of their work trucks) and cut it to fit your floorpan........A guy I know got some used 4x6 mats from a local hockey rink and did the entire floor of his Scout. It looked good and really deadened the road noise- I assume it would keep the heat in too!!!!!!
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    As of now I have 3.08 gears in a 10 bolt running on 33's, but I have been looking for a 12 bolt to rebuild! Anybody have one?
    If it ain't a Chevy, don't raise it up!
  9. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'll be running 3.73 gears with my stock 350 engine. I already have the gears. Just saving to rebuild both axles (10b front, 12b rear).
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  10. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i bought a HUGE roll of that Heat Shield stuff from JCwhitney....good stuff.
    3.08s over here w/33s. used to have 4.11s in the rear, when the choice came to change the front or rear i chose to change the rear. sand dunes and highway driving dont stress the gears as much a rock crawling and trail riding.
    Knife.
    knife.coloradok5.com
  11. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Hopefully I will be pulling out my 12B within the next two months. I just hade it rebuilt 6 months ago. All new bearings and seals throut. It also already has 3.07's in it so there would be no regearing. So if you still need one in a couple of months just keep your eyes open on the board and I will let everyone here know when the 14B is in and the 12B is out.
    [​IMG] I have to agree with the Puddy Cat. [​IMG]
