Intake and air cleaner update
Discussion in '1982-Present GM Diesel' started by RLBstein, Oct 24, 2002.
  1. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    Well I finally did it...I installed the J-code intake from my extra 6.2L in the garage and personally don't really notice a difference. I also removed the air silencer and stock hose and replaced it with 3 inch pvc and ran it from the grill to the air cleaner assembly. I think it has a little more pep to it with these new installs but probably as much as a good wax job on the body would do /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif. I wasnt prepared for the extra things I would have to do to get it to work...such as replacing the left side valve cover and figuring out a new place to mount my secondary fuel filter (since it mounts to the old intake) But I don't regret it...oh and one other thing, it seems a lot louder now under the hood. /forums/images/graemlins/confused.gif
  2. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    I had that done (the air cleaner intake hose), and I didn't notice much difference other than noisier and easier to get to stuff under the hood without that big piece in there. I did notice a bit more 'seat-of-the-pants' feel when I put a K&N filter in tho... /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Jon /forums/images/graemlins/burb.gif
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I used 4" pvc. It will suck my shirt in if I get too close!! I noticed a difference when I put the PVC in. Did you enlarge your hole at the front?
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    It got noiser because you removed the silencer. There is nothing covering the intake, no throtle plates such as in a gasser, to keep the internal engine noises from reaching the driver. So GM installed the silencer/muffler to quiet things down.
    I too installed a J code, and didn't notice any power gains. Before the swap, I pulled my fifth-wheel up a large hill several times noting the speed each time. I then did the same test again after swapping intakes. I noted absolutely no improvement whatsoever. Still, I think it has to help the engine breathe much better. I know it will help when I get my turbo installed.
    Besides, it'll make changing the fuel filter much easier, now that you can get to the thing, right? /forums/images/graemlins/wink.gif
    Casey
  5. RLBstein
    Jul 2, 2000
    179
    Pensacola, FL
    Are you still using the plastic piece that mounts in the radiator support, the flat faced circular piece that prevents birds from flying into your intake /forums/images/graemlins/blush.gif
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    No. Wide fricken open. I even cut the front of the grill up so it was completely unrestricted!!
    Check out my pics in my sig. It shows how wide open it is.
