Intake bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mouse, Apr 6, 2005.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Ok, I thought I had this beat with the new motor. When I assembled the engine I made sure to coat the intake bolts with RTV to prevent oil from making its way out through the holes but to no avail. A week since first firing it up, the first traces of oil are now coming out of the middle intake bolts. I have washers on them and used blue RTV. Any ideas?
    Thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Are you sure it's oil? There is no oil pressure in that area but usually what happens is the throttle shaft is loose in the base plate and fuel seeps out and mixes with dirt and it looks like oil. Just a thought.
  3. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Use thread sealant, not RTV
  4. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Definitely oil. Carb is new.
    I'll get some thread sealant.
    Thanks.
  5. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Yea when I put on my edelbrock intake I did not use thread sealant. About 2 days after I got my engine fired up it started to pool up real bad.
    Then I put on some thread sealant and it has not lieaked since.
    Adam
  6. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    I used black rtv when I put my engine together. The blue rtv is mainly used for a water sealent and black is for oil.
    This was my first engine. And with as much money as I put into the engine, "BELIEVE ME" I made sure what the difference was. My engine doesn't leak a DAMN thing!!!!!!!!!!!!!!!
