intake center bolt question
Discussion in 'The Garage' started by sweetk30, Sep 28, 2006.
  1. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    i know the older intakes were all the same. but tbi and newer the 4 centers were changed for the hold down angle.
    didnt someplace sell special washers for this to let the bolts sit flush .
    of do you know the 2 diffrent angles.
    ya ya i know just hog out the holes and be done with it. but i dont like to as it is to be done right 1 time and forget about it.
    thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    McMaster Carr sells the spherical washers but you still need to elongate the holes and there isn't enough material for the washers to sit properly once done anyway so i wouldn't worry about them. Once you elongate the holes you can then use a grinder to change the seat angle and you'll be fine.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    The intake ports don't line up correctly either. If you want to do it right, get the right intake.
  4. sweetk30
    Nov 1, 2004
    25,536
    532
    :confused: :confused: :confused:
  5. dyeager535
    26,976
    You are thinking of the Vortec ports, but the bolt pattern on those is entirely different.
  6. 1977k5
    May 26, 2003
    9,992
    130
    Yeah, my bad.
  7. diesel4me
    Jul 24, 2003
    17,540
    928
    Massachussetts
    one trick I saw...
    I saw one guys 350 that he put a carbed intake on, by hogging the holes out enough to get the bolts in--then he used a 1/2" drill to "countersink" the intake holes some,and he used old rocker arm balls as conical washers!..I thought it was a pretty good way to do it..:crazy:
