Intake for TBI with Vortec heads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Mar 13, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I did some checking and here is what I found. Edelbrock is not planning to make one at this time. Good news is that you can get one from GM Performance for $395.00. Just thought all of you might want to know.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Do you have a part number for the GM intake?
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Does anyone know if the manifold fromk GM is made for performance or just a stock replacement that they made to fit?
    90K5
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Did not get a part # because you can get it from your local dealer. You might even be able to get a better price too. It should work fine with any setup as far as performance goes because you are going to be limited by how far you can go because of the TBI itself.
  5. dyeager535
    26,975
  6. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    These part numbers were posted a few months ago here on CK5. Trust, but verify.
    TBI Vortec Aluminum Intake Manifold GM P/N 12496821
    Vortec Exhaust Manifold GM P/N 1257828
    Other parts necessary for the EGR Modification:
    - EGR Tube GM P/N 10220275
    - EGR Fitting GM P/N 12552329
    - Vacuum Controlled EGR Valve GM PN 17052693
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Here are the prices from <A target="_blank" HREF=http://www.sdpc2000.com>http://www.sdpc2000.com</A>
    1. Fitting for use with Vortec EGR Supply Tube 12552329 $4.08
    2. EGR Supply Tube 10220275 $52.31
    3. Left Hand Vortec Exhast Manifold 12557828 $80.25
    4. Vortec TBI SB Chevrolet Intake 12496821 $329.95
  8. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    Not cheap. All that costs about as much as the heads.
