Intake Gasket Digestive System
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudober, May 2, 2002.
  1. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    I have a 406 in my 78 Jimmy with Edlbrock alumiun heads & intake. I had a intake leak on #6 cyl. so I changed gaskets.I found the gaskets on both sides to be distorted, as in curved toward the middle of the port.Between 6&8 the middle was gone, & the top sunk in causing an air leak.These were Fel-Pro gaskets been on for one year.
    Anyone else heard of this? And no the intake was not lose.
  2. Grim-Reaper
    7,385
    Atlanta
    Take a machinist rule and check the intake for warp. Could have also been improperly torqued. was the heads or block decked? Manifold may not be be wide enough if so.
