Intake manifold holes?
Discussion in 'The Garage' started by camok5, Jan 25, 2007.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Can some one tell me what the hole inside the manifold are for. I have seen them with and without these holes? You can see them when looking straight down through the carb opening, they are about 1/2'' wide. Kinda like these.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    possible for heat riser flow or egr stuff. never seen a gm with them.
  3. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    me either...the only thing i can think of is for is if under the manifold(between the block and manifold) there can be vaccuum nipples to run vac lines off of since i don't see really any up top.
  4. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    There inside the manifold not under it (like in the pic) so I dont believe they would be vacuum ports. I pulled a GM edelbrock performer off the engine I'm building that had them. At first I though it was some kind of casting error but when I started looking online I found more pics of different manifolds with them. I'm still confussed as for what they are for and wouldnt fuel get trapped in there?
  5. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    being its a dual plane manifold; does the upper plane crossover the lower plane on that manifold?
  6. dyeager535
    26,975
    Oldsmobile used a setup like that, fed EGR through pipes screwed into the intake in about the spots in the picture.
    Never heard of it on Chev motors though.
  7. 76zimmer
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    Are they threaded?
  8. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Nothing attaches to them they are just holes that go into the bottom of the intake(not threaded) and I have never delt with them before but the manifold came off a chevy engine( not the same as the one in the pic, just using it because it shows the holes clearly).
  9. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    This is one like the one I pulled off.
  10. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Someone on Pirate just told me that they are the blow holes for the EGR, is this true?
  11. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    The edelbrock TBI manifold I put on my big block has those holes also. They go to the EGR.
    Russ
  12. dyeager535
    26,975
    Yeah, threaded.
  13. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    probably EGR passages..
    Mopar small blocks used similar holes with "floor jets" inside the intake to allow EGR gases to mix in with the fuel/air mixture to be re-burned..I'd guess the Edelbrock manifolds use a similar setup,going by your photos...:crazy:
