intake manifold Q?
Discussion in 'The Garage' started by nicotine, Dec 27, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    i am getting ready to put a 350 in my truck and i need to know if all SB chevy maifolds will work on a 350 because i have a 400 sb manifold will it work? or should i buy a new one?
  2. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    It should work. I know all the aftermarket manifolds are listed for engine sizes 265-400sbc.
  3. nicotine
    Jan 11, 2004
    116
    the only thing that will be diffrent would be the plug numbers on the manifold correct?
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    ... :blush:
  5. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    all small blocks were the same plug # is the same
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    ex manifold most likly a smog one, and heads on motor are most likly pre smog . the imfumus 7th exaust hole scenereo.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it depends on what heads, TBI, Vortec, or just plain carb heads. the bolt pattern is different on all 3.
  8. nicotine
    Jan 11, 2004
    116
    they are plain carb heads it is a sb 400 manifold going to a 350. i though 400 plug #'s were in diffrent spots?
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it will bolt up just fine. may be the same intake found on some 350s :thinking:
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    400 plug numbers are not different lol
    same deal 55-90's cept that in 87-90 some are TBI others are still carb(changeover years) and the center four intake bolts changed the angle they are drilled and tapped
    but there is an easy work around for this
    put the intake on, you have nothing to worry about
    good luck
