Intake manifold sealing
Discussion in 'The Garage' started by bigcat44, Apr 3, 2005.
  1. bigcat44
    bigcat44 Registered Member
    Jan 29, 2005
    59
    Albuquerque
    I spent the better part of yesterday and today replacing my stock TBI intake manifold with a new Edelbrock Performer. I used the Fel-pro gasket set for the sides and various components and used some permatex (I think) glue for the front and rear...fired it up and it leaks from the back. Should I be using a different sealant or gasket set? I am going to be pulling it and re-sealing it next weekend so I figured I would get some better advice on this! The leak (coolant) is coming from the back corner. Thanks in advance for any and all help.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Coolant from back corner? Did you gouge the intake, head, or gasket? Never seen a leak back there. I always use FelPro gaskets and never use rubber end seals(always RTV the rails) so sounds like you did everything right to me.
    Doh just thought of something, did you put RTV on your heads to keep the intake gaskets from sliding?
  3. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    1st time i did one it leaked back there. took it apart amd used the rubber seals, and it worked perfect. might have nudged it the wrong way when you put it on. if i did do it again, i would use rtv though.
