intake manifold
Discussion in 'The Garage' started by hunterguy86, Nov 23, 2005.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Can I swap a non egr manifold to my 86 k5 305 engine? What would be involved in doing this as my truck has all that emissions stuff and vaccume hoses everywhere. is it possible or should i just get an egr manifold?
  2. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    if you are keeping it smog? If so then get an egr maninifold
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    If yer not gonna have to smog it you can put a Non EGR manifold on a engine with EGR heads. Ive done it a couple times. No probs. If you are dealing with smog get the EGR manifold and good luck with the spaghetti of vacuum lines and wires. Im glad I got rid of my 86 K5. My 81 was alot more managable. And I luv my 73!!
  4. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    no smog to worry about here. So how would I go about figurin out the vacume lines? any place to research what everything does so i can decide what i can and cant do away with? I'd like to simplify things a bit under the hood if possible.
  5. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Get a manual. Chilton has the diagrams in it. Maybe somewhere online has the diagram. Or just yank 'em all and send vacuum to brakes, distributor, and that should be all.
  6. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    how about the vacume canister? doesnt it vent the gas tank?
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If your talking about the coffee can shaped thing on the core support, no idea what it vented, but on my 1975 burb (non-egr) I took that thing off and just put a filter on the end of the hose like you'd find on the end of the diff tube.
  8. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    that canister collects the gas fumes from the fuel tank and then allows the engine to burn them
  9. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    their is no reason you cant, just check with your smog regulations unless its a trail only rig.
    it will work fine!
    LUKE
  10. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    what carb are you running? I have the factory Quadrajet. All that is hooked up on my 75 is brake booster and dist. and Transmission. My trans and brake booster are on one port off the manifold. (Don't like that) Not sure where the vacuum port would be for the brake booster coming off the carb. And i don't have the canister installed at all. All my misc ports are capped off.
  11. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    im runnin the stock qjet. I think i wanna stick w/ it. It works well for me.
