Intake Manifold
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Me89'Jimmy, Feb 1, 2004.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    I pulled the heads of my 350 last night, the only problem is i managed to get dirt in nearly every oriface of every part of my engine, head, intake and Throttle body, /forums/images/graemlins/doah.gif/forums/images/graemlins/angryfire.gif, since the heads are going to the machine shop i need to clean up the bloody mess i made, my question is, can i put my entire manifold with throttle body still attached into a parts washer and get decent results, or am i askin for trouble, also which would be better to use, kerosine or pure alcohol to clean out the ports, throttle parts etc. Thanks /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
    Quick update, does anyone know anything about Pro Topline heads, the machine shop said they found a set of performance heads that would be cheaper to throw in than having my stocks, ported, new springs, guides the whole bit. I searched but to no avail. Lemme know, thanks.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Id'e pull the throttle body off before cleaning.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    WSeperate the throttle body. You can blow the intake out with air or even water.
    Spray the TB with carb cleaner, and look it over.
    Did you get anything into the cylinders? A shop vac is good for getting most of it out, and follow up with rags, or paper towels. Be careful around the rough casting areas, as the rags or p. towels will leave crap behind.
    Just take your time, all is still good....
  4. Me89'Jimmy
    Oct 6, 2002
    127
    Sykesville, MD
    i got a couple of clumps of crap in the cylinder and a fair amount in the center of the block, the area thats under the intake manifold, and just to be on the safe side prolly got some down into the oil pan. /forums/images/graemlins/waytogo.gif
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Re the pro toplines. I have not heard anything bad abuot them. A buddy of mine just put a set on his SBC race car. Got it up and running. Likes them so far but he has not raced them yet.
    The SBC torkers are only around 500 bucks not bad for a set of new heads.
    I am thinking of getting a set for my Mustang.
    http://www.protopline.com/index.asp
