Intake size question
Discussion in 'The Garage' started by BigBurban350, Jun 9, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I have an 84' 305 engine that I just got done porting the heads on. /forums/images/graemlins/thinking.gifNow is a 350 intake got larger runners then a 305's? The ports were larger on the intake then the heads, now the heads are slightly bigger so I want to match it up with an "if so" larger 350 intake.
    OR! Should I put this on and wait until I got money for an edlebrock performer intake?
    I want to stick with dual plane manifolds for the torque.
  2. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Wait for the Edelbrock Performer. You will get much better throttle response and driveability from the Edelbrock. The stock 350 manifold isn't worth wasting your time.
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    What he said ^^^^^^^^
  4. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Okay, ill have to settle with the stock until winter /forums/images/graemlins/thumb.gif
  5. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    THE 350 MANIFOLD YOU HAVE WILL BOLT RIGHT ON TO YOUR 305. THE 350 ONE COULD VERY WELL HAVE LARGER RUNNER WHICH COULD HELP YOUR MID RPM BUT SLIGHTLY HURT YOUR LOW RPM, DUE TO THE VELOCITY OF THE AIR/FUEL. IF YOUR NOT WORRIED ABOUT LOSING A LITTLE DOWN FOR GAINING A LITTLE UP TOP, AND YOU HAVE THE TIME, THROW IT ON. JUST PORT MATCH THE CYLINDER HEADS TO THE INTAKE, THIS WAY ITS ALREADY DONE WHEN YOU EVENTUALLY GET YOU EDELBROCK. I PERSONALLY WOULDN'T WASTE MY TIME PUTTING IT ON IF YOUR GOING TO SWITCH TO EDELBROCK ANYWAY, UNLESS IT IS A FACTORY PERFORMANCE MANIFOLD OR IF IT ALUMINUM.
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Wait for the edelbrock, unless that's a Z-28 manifold. Port the openings on the heads and the intake to the gasket, and you will be set....
