intake
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 69K5, May 13, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    does anyone know which port is supposed to be resticted on a 69 .350? my gaskets had pop in resticrors bot no where to put them.
    thanks
    nathan
  2. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Generally, in the center of the heads you will see something like this [0] ... where the water jacket surrounds the exhaust riser and that plug is to block off the exhaust if you want to keep hot gases away from your intake/carb. Just don't use it if you want a choke for cold weather driving. Gary
