inter-changability of parts...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Jun 14, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i am wanting to take as much as possible off my 1978 chevy 3/4 ton truck and put it onto /into my soon to be 1974 blazer...
    what will swap..
    i know the motor/tranny/np203 will do it fine...
    what about the lift???
    body panels? doors???
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I belive that everything from the cab forward should swap over. I'm not sure about the lift though, but pretty much everything else should bolt in.....
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Front springs will swap, but if the lift has rear springs, I think the 3/4 ton rear springs are 56" and the blazer has 52" rear springs. Im not positive about that though.
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Doors won't fit unless you cut down the ones off of your 78. Fenders, hood and all the other front end parts will interchange. All the suspension will bolt up unless your rear springs on the 78 are 56" long.
    Rene
  5. reddog64
    Nov 9, 2000
    3,325
    hey rene!!! long time man...
    the doors wont fit huh... that's ok...
    I learned to weld... kinda... hehe...
    rhe rear lift is block and adda leaf, so it's ok...
  6. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Yeah, it's been a while dude! Looking to re-use those fancy fenders huh? /forums/images/icons/grin.gif
    The doors are pretty easy to do...if you need a template to cut yours I have a 74 door you could take measurements off of. I got it with my 74 for that exact reason. It's in bad shape but it's an original 74 door so you can see where the cuts need to be.
    Rene
  7. reddog64
    Nov 9, 2000
    3,325
    what do i have to cut off the doors???
    what years will fit the 74???
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you don't want to do any cutting, find a door from '73 - '75. /forums/images/icons/wink.gif
  9. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Wes, usually 73, 74 and 75 doors up here are pretty hard to find in decent shape. I haven't run across any here at all...much easier to cut newer doors.
    Aaron, the 74 doors are cut roughly at the top of the butterfly window and across horizontally at the window edge. Basically the part that frames the window gets removed. There are some caps and junk for seals that are needed but you can get those from LMC
    Rene
  10. reddog64
    Nov 9, 2000
    3,325
    oh yeah... duh.. full topper... my bad...
    what about a soft top...???
  11. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    You can run a soft top...STC makes em as well as Best top and maybe a few others...still need to cut the doors though /forums/images/icons/smirk.gif
    Rene
