Interchangability of a 14BFF and a 14BSF for a Burb
Discussion in 'The Garage' started by BurbinOR, Aug 5, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Wondering if I bought a 3/4 ton Burb, would my current 14BFF rearend bolt into the Burb? LIkewise, will a 14BSF bolt into my Blazer? All this with little effort? /forums/images/icons/tongue.gif
  2. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Yes they should swap out just fine. The 14SF in mine came from an 85 3/4-ton burb.
  3. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    DEPENDING ON YEAR I JUST SWAPED A 14SF INTO MY 90 JIMMY
    OUT OF A 88 PICK UP I HAD TO CUT OF SPRING PADS AND RELOCATE
    THEM FARTHER IN. EVERY THING ELSE FIT RIGHT PARK BRAKE CABLES WERE A LITTLE LONG BUT ROUTED THEM UP OVER SPRINGS ARE OK NOW THE BEST PART IS ITS 4 INCHS WIDER AND TRACKS WITH FRONT. /forums/images/icons/cool.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A 'burb is just a long version of a K5. All of your drivetrain is a direct bolt-on to a Sub. /forums/images/icons/cool.gif
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    like steve said it depnds on what year you have and what it is swapping into.the bigest problem you'll have is the spring pads and e brake lines,depending on years again.just measure everything before you start ripping stuff apart just in case you have to change mounting hardware. /forums/images/icons/laugh.gif
