Interchangable Master Cylinders?
Discussion in 'The Garage' started by k5blaze, Feb 17, 2004.
  1. k5blaze
    k5blaze Newbie
    Feb 17, 2004
    OH
    well i just found out that the master cylinder on my 78 k5
    is no good. i was wondering what year master cylinders were interchangable?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Pretty much most of them are. You can use a 1/2ton or 3/4ton M/C from like 73 - 84 or 85 i believe /forums/images/graemlins/thumb.gif
  3. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    Parts store would know for sure. I know by ~'85 there was a difference, and the newer masters won't fit the older brake boosters. I put a later model master on my Chalet (hey, it's overweight, it needs the help!) and had to switch to the later booster too.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it will work, but 1/2 ton is oddball and has lines swapped fron to rear, and in 80 they started with aluminum body m/c's especially on base model c-10's
    3/4 and 1 ton have lines setup same as eachother, opposite of 1/2 tons
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I was wondering baout this too. I want to put a newer (like 98 or so) Brake booster and master cylinder on my 72. I have seen it done, does it just bolt right up?
  6. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I put power brakes on a buddies 70 2x awhile back. For some reason, And i don't really recall, I couldn't use the late model booster. I had one laying around we tried to use. I think the diameter was bigger and it wouldn't clear the hood.
    there is a difference in the pilot size of the master cylinders from early to late. But i don't know what the year split was. If you change the whole booster/master assembly, It will work. The booster/master in my 73 came from an 85 3/4 ton.
  8. dyeager535
    26,980
    In cars around '91 apparently the bolt spacing changed. I wouldn't doubt it happened in trucks with the new body style as well, but I'm not sure when...I have the ABS bracket out of an '88+ body style truck bolted to the studs for the booster/master cylinder in my '86, so if that measurement did change, I don't know when.
