Interco TrXus STS tires definately work!
Discussion in 'The Garage' started by Mudzer, Mar 25, 2002.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Tested the tires at Disney this weekend. We did a mix of climbing solid rock ledges, rock boulder crawling, and some muddy trails which were straight up and down (ask anyone who drove them) and my STS' never slipped once. They outperformed my truck! During the trail run, we crawled up several crevasses which were very deep. Once the truck was level in the crevasse, you could stand under the rear bumper in the center of the crevasse! So, you definately needed side bite to keep centered. They never once slipped. We drove trails with 44" tire sized ruts. On several occasions I tried to climb out of the ruts and all it took was a turn of the wheel and it would steer out without a problem. I aired them down to 8 psi and the sidewalls flexed very well. They are spongy at this pressure, but work great. I am very impressed with the performance of these tires. In fact, I may sell the Boggers and run these full time. There were several "Seasoned" wheelers on this run and they are impressed with these tires as well. I will try to post photos adn video of the tires in action.
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I'm sold!
    Can't wait to put a set of these on my FunBuggy! When will they be available?
    Marv
  3. Mudzer
    3,639
    Missouri
    Marv,
    Not sure about the availability. I will call my contact and find out for you and repost.
    Neil
  4. 79k20
    79k20 1/2 ton status
    Oct 15, 2001
    144
    s.e. kansas
    <font color=orange>Good to hear. I might have to get me a set of them someday.</font color=orange>
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Hey Neil. What size where you running? Sounds like the perfect tire.
  6. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    On <a target="_blank" href=http://www.intercotire.com>www.intercotire.com</a> they classify them as an all terrain or sand tire. Sounds like they under estimated them.
    Evan
  7. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    Neil has the 38's I believe.
  8. Mudzer
    3,639
    Missouri
    They are 38"x15.5" wide for 15" rim. I have them mounted on a 15x10 rim with standard offset.
    Yes, Interco did market them initially as a Sand/Snow/All-terrain tire, but I wanted to test them for Interco to imphasize the "All Terrain" designation. Most people who look at them say "They dont look like a very good Mud tire", first of all - Interco makes the best mud tires on the planet. Secondly, these tires do work great in the sloppy stuff. If it were gumbo mud, there is probably not a tire out there that works absolutely perfect. They all hold mud at slow tire speeds, unless you own a Mud Drag car with an 800 inch motor spinning the tires!
    Heres proof of their "mudability". I have a set of Boggers, and I have yet to see my Boggers pull me out of a muddy rut sideways. Try this sometime: Pull into a rut made by a 44" tire, which is full of water. Stop in the deepest part of the rut, then turn the wheels to the bumpstops in either direction. Then apply easy throttle and see if your tires will crawl out of the rut. Well, these tires did! In numerous cases they excelled my expectations. I did not add any balance weight to the tires. Just mounted them as they were and drove over 15 hours of highway time without a problem.
    I haven't tested them in Sand or Snow, but I would say if that is what Interco designed them for, they should do great.
    I tested mine at 8 psi and they seem to have pretty squishy sidewalls at this pressure. The footprint definately gets bigger at this pressure though, so they should work great on sand around the 8-10 psi range. I would be willing to bet since they have a wide profile, they probably could be ran at an even higher pressure on sand. All I know, I am very impressed with these tires. Im selling my Boggers and using these full time. Can't wait to wheel with them again.
  9. aksidentproan
    Dec 8, 2001
    477
    Maryland
    Do you have any pictures of these tires. They always look different then the pics on the interco web site.
    Evan
  10. Mudzer
    3,639
    Missouri
  11. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    how much you want for the boggers?/forums/images/icons/smile.gif
  12. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    It doesn't matter what he wants for the Boggers, the storage fees have already surpassed their value...
    Wouldn't you agree Neil?
    jk
  13. Mudzer
    3,639
    Missouri
    Outrageous! Shagz will be upset when he finds out you are charging him storage! Besides, if they were mounted on 8 lug rims, you would have them on your Blazzo in a second! /forums/images/icons/wink.gif/forums/images/icons/wink.gif
    By the way guys, the Boggers are sold!
  14. shaggyk5
    1,610
    SE pennsylvania
    well, they went quickly. Its ok, I really want 39's anyway......
  15. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I finally saw an add in the new issue of Petersons 4 wheel &amp; offroad this month...Tyres International has them for sale and a pic of them. I thought the prices looked very reasonable, was I seeing things??
    They list 21/44-15's for $229...these are 21 inch wide 44 inch tall tires right? Isnt that pretty dang cheap for 44's??? Misprint or is that real?
  16. Mudzer
    3,639
    Missouri
    I think the pricing is much cheaper on these tires.
  17. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    That is pretty sweet then, esp if they work as good as people are saying. Of coarse once the 4x4 magazines test them and say they are great the price will probably go way up...maybe not /forums/images/icons/smile.gif
