Intercooler
Discussion in '1982-Present GM Diesel' started by 79k20350, Dec 19, 2005.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    So is running an intercooler with a banks setup worth it? i cant imagine it wouldnt be? my unlcle is doing a 6 gun on his ford superduty so i could nab his intercooler... mounting it wouldnt be hard. just want to know what type of gains to expect?
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Uh, no. The whole point of an intercooler is to drop the IAT's, and the lower you can get those the lower you get your EGT's. Most people who install an intercooler and change nothing else actually see a 1-3psi drop in boost on the intake side, and they dont see any power increase or loss, the same exact ammount of air is getting into the motor as before, its just cooler. What they see is a drop in EGT's which lets them either be happy that their EGT's are lower and give them the ability to run with their foot further in it before hitting that critical temp, or dump more fuel into the motor before cooking it.
    "+40hp minimum", thanks for the laugh.
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    the drop in boost is expected, somethings in the intake tract...but the cooler intake temps are more plentiful wit oxygen so i can only imagine youd have about the same if not more power? but also like said your egt is lower
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    An intercooler on a fairly stock 6.2L with a Banks turbo is probably not going to gain you any real world power. A Banks turbo doesn't create enough boost to warrant cooling it down and losing a bit of boost.
    I wouldn't mind installing an intercooler on my engine, but I don't want it for the possible power increase, but rather for the cooling effects. My engine gets pretty hot pulling up long grades with a large load. My EGT's are actually pretty good though.
    I saw 18 psi on the boost guage the other day...the highest boost I've seen yet. That's the kind of boost you need to have before an intercooler really becomes a necessity.
    Casey
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Just for fun, I threw a thermocouple in the intake while towing. Max temp was 220-230 *F IAT, up grade, 10,000 lb trailer, with the banks running 7 psi (4000 ft altitude). FWIW.
    Like Casey said, not worth it in stock/banks form.
