Interested in helping me ID some parts?
Discussion in 'The Garage' started by fireplug, Sep 28, 2006.
  1. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Thanks for playing! :D
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the crossmember is for a 203 transfer case and the bottom one is a 350 tranny to 203 adapter
  3. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Thanks a lot! :bow:
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Bellhousing is BOP maybe?
    How big is the bore for the input shaft bearing retainer?
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    looks like it had one of those A883 OD 4 speeds bolted up to it...
    Rene
  6. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    BOP? I'd have to measure. Shop and home are an hour apart. :mad:
  7. dyeager535
    26,980
    BOP have a different bellhousing to block pattern, IIRC its the middle of the 3 bolts on either side, and that one looks like a Chev pattern to me...not to mention that one of the 4 bellhousing to transmission bolts is offset, and AFAIK the 465 is about the only GM tranny that did that.
  8. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    I was led to believe that all the parts I acquired were associated with each other so to speak. I assumed that this was a t350? Maybe not? Yeah it is.
  9. dyeager535
    26,980
    Where's the vacuum modulator? At the rear, TH350, out the side, TH400.
  10. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    I didn't manage to get pics of the other side. I'm pretty darn sure it's a 350. I'll check tomorrow.
  11. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
