Interesting D60 product
Discussion in 'The Garage' started by Shaggy, Feb 13, 2003.
  1. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    That's interesting. Dunno about the $250, but I'd try it out for free! /forums/images/graemlins/grin.gif
    Must be pretty proud of it, with the disclaimer and all...
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Wes was talking about making something like abuot 10 months ago. Looks pretty sweet though...
  4. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Welderboy on PBB uses the rollerbearing set up on his fabed knucles.
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Anybody seen this before?
    Yup. On the good ol' closed-knuckle stuff /forums/images/graemlins/grin.gif
    I do like it though. /forums/images/graemlins/thumb.gif
  6. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    He said it was a standard bearing. So who will be the first on Ck5 to figure out what Timkin bearing he is using?
  7. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I like his BS discalaimer about prosecution if you copy it. ROFLMAO. Patent pending.
    Get real.
    Depdog
  8. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Wes probably already knows. /forums/images/graemlins/smirk.gif
  9. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I smell booty-fab
  10. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Neat idea, but there is no way to seal that bearing from the environment. Mudders need not apply.
  11. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    It will be just as sealed as the nylon upper bushing. You just have to grease it after an outing.
  12. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Now with this and if someone would adapt a setup like the bearing buddie to keep trailer axles greased. Then just fill it with grease every so often. /forums/images/graemlins/shocked.gif
  13. Sundowner
    Sundowner Newbie
    Feb 6, 2003
    I like the idea a lot, but I fail to see where the $200 pricetag comes from. if he's so pissed about copies, it must be easy to make. glad my machinist is on speed-dial
  14. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    Nice deal, wonder if it still used the spring to preload or if it gets "hard" shimmed to establish preload??? Did anyone look at his other auctions? He's sellong D60 caliper brackets that accept 1/2 or 3/4 ton front calipers. What's the point? $250 to save some grinding maybe?
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Like it was quoted above....Welderboy on POR makes and supplies these with his one-off bomb-proof knuckles.
    Last I heard, thru the grapevine, that these bearings to eliminate the plastic bushing, are off road use only. Meaning that they will not survive to the everyday use of driving, etc. unless you want to carry a grease gun with you everywhere you go. /forums/images/graemlins/tongue.gif
    What I'm trying to figure out on this bearing kit on eBay is since the bearing is shorter in heigth than the plastic bushing, what is offered to take up the slack to get the spring to compress under the cap? Sounds like you gotta stack several washers to make up for the bushing thickness.
    I do like the idea of a tapered bearing to take place of the plastic bushing, but until someone can design one that would basically be "maintenance-free" (hint: drive it and forget it), we are probably gonna be stuck with these plastic ones for the time being. /forums/images/graemlins/frown.gif
