Interesting day....
Discussion in 'The Lounge' started by ryoken, Apr 30, 2007.
  1. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    So friday at work, me and one of the other mechanics take this 55 Ocean sportfish out for a test run...
    something like this...
    So we're jamming down the bay doing about 30 mph when the starboard motor temp just goes to about 250 in about 5 seconds, alarm goes off and then she stalls... :eek1:
    Now the reason for the eek smilie is the fact this boat has a pair of Detroit, supercharged, twin turbo'd 892's in it.. I've NEVER seen a Detroit just shutdown like that from any heat issue, it's usually siezing or fuel related..
    So I go down to take a peek.. Let her sit a bit to cool down, then have the other guy try spinning it... Well, let me tell ya, if you've ever seen a runaway diesel, it's a scary thing.... Especially in a 6' x 10' space with 4 ' ceilings...
    Well, it turns out it had a cylinder that was hammered and decided to nuke itself, and in doing so, ruptured the fuel rail that runs above it INSIDE, yes I said inside the valve cover.. Thats how these work, just a lift pump, no injection pump. mechanical rocker fired injectors create their own pressure.. All under the valve cover.. :rolleyes:
    Well, what happened was this fuel rail for the injectors was dumping diesel fuel right into the crankcase at a high rate... When we refired it, it was running off it's own crankcase juices going right up into the cylinders... After when I checked the oil level, it was double... :haha:
    Thank god, Detoits have an emergency air dam door you can flip, that'll kill it.. Most diesels don't.. Even then, that 4 to 6 seconds it took me to frantically get to the door, were shall we say, heartpounding.. (insert peeing in pants smilie) Freakin thing was on it's way thru the roof...
    Scary thought having one of those screaming as much as she'll spin till it grenades... :eek1: :wink1:
    Boats a pos, I'm glad this asshat is looking at 30's.....
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    No Thanks. :rotfl:
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    wow, we had a power cart with a detroit diesel runaway, it was cool, the dumbass running it couldent figure out how to shut it down even though there is 2 emer. shutoffs.
    it sounded like it was going to explode, the exahust manifold was heat welded to the head, we picked the engine up by the header with no bolts in it.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    At a place where I used to work they had a JD 4045T run away. One of the guys there had re-assembled the IP incorrectly and as soon as they test fired it for the load test it went instant redline. They had nothing nearby to block the intake with and it eventually threw a rod right there on the test stand...:doah:
    Needless to say a block off plate became a permanent part of the test procedure inventory after that.
    Rene
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    My head mechanic was at Detroit school and the instructor put a phonebook in front of an intake, it sucked it thru and made confetti... :eek1:
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    holy crap!!!!!
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Thats exactly what I said...
    I need them to send me to Detroit school, sounds like fun...
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    no kidding thats something id like to see
  10. sweetk30
    Nov 1, 2004
    25,550
    543
    horseheads , ny 14845
    friend went to school for auto . the class building had a big v12 bolted to a stand to the floor. one kid remaned the ip and did the same thing. luckys instructor was vary smart and stuffed the big big co2 fire extiguisher down its mouth and had just the right amount to stall it out. or that would have left a little hole in the floor. :rolleyes:
  11. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    heh had a guy try and shut down a powerchoke once with a clipboard, you know the pressboard kind, it ate it...
  12. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    "My diesel ate my homework"
  13. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    HAHA! :haha: :haha:
