Interesting find: high gears in a 14FF...
Discussion in 'The Garage' started by thatK30guy, Jan 27, 2007.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Whats the highest (numerically lower) gears you have found, seen or heard of in a 14FF?
    Last night while at a buddies shop, we decided to pull off the drums on his 1980 K20, which of course, came with the 10 bolt front and 14FF rear.
    I had owned this truck before I sold it and he got it later from the buyer I sold it to. We had all known from the PO that I bought it from that it had HIGH gears in it. So last night we decided for $h!ts and giggles, to pull the covers off and find out exactly what ratio they were. We were in a shock after the covers were removed.
    In the 14FF, the stampings on the ring gear showed 14 and 45. Did the math and came up with 3.22 ratio.
    In the 10 bolt, the stampings were 13 and 42. That came out to 3.24 ratio.
    Now the big question is: has anyone else ever seen or heard of this ratio in a 3/4, or even 1 ton?
    We were all standing around like fools, dumbfounded, with our jaws on the floor. We all agreed that we've heard of 3.42's and 3.73's but never heard of 3.22 or 3.24.
    Anyone else care to pitch in and elaborate? Would this kind of ratio be a super rare set that may be worth something on eBay? Opinions please....
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    wanna sell those? i've heard of them but don't see them much. i've got a 3.42 rear in my truck.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    My buddy says that if he decides to scrap the truck, then he will give me the ok to sell them for him. We are still doing investigations on this odd ratio. He's a full-time mechanic and has never heard of this ratio for the GM 3/4 tons.
  4. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I've seen a set of 3.22's before in a Burb (can't remember the year), definitely rare stuff.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    how about a set of 2.29's in a car rear :crazy:
  6. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Yes, I have heard of 3.23's in a 14FF. 3.42's also. I would like to build a Burb or other rig, 2wd with a 4BT, NV4500, and 3.23's. I think you could really get some mileage from a setup like that.
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    I've got a 10 bolt front with 2.56 gears in it, 41 teeth on the ring gear, and 16 on the pinion, yes I counted serveral times, lol
  8. Currank5
    Currank5 1/2 ton status
    Apr 4, 2006
    244
    South Dakota
    Those ratios are around. Not the most common esp. in a 14 bolt. RPO code GU5= 3.23 ratio. When i got my blazer i found out i had 2.73 gears. Wish i had checked that out when i got it but i was just happy to get a good deal on another blazer.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a buddy of mine had 3.23s in a 3/4 ton axles, it was a 14bsf though. i always thought that 3.42 was the lowest in a 14bff.
  10. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    I know the the lower the gear the higher the GVWR. Check the specs on the truck and see what it is.
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I saw a 80's 2wd suburban at the jy with a 3.23 14b ff. (the diff cover was off, gears were rusty)
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I remember a few years ago Ddraggoon said he had a 14bff with 3.23's in his Suburban.
    Harley
  13. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    im still anixous to tear into the 10 bolt on my K10...3.08s at least but it felt higher geared then another kids truck who had 3.08s, He thought I might have 2.80 somethings
  14. dyeager535
    26,976
    I have the 10 bolt 3.23 gears out of a 3/4 ton truck that was 14FF in the rear.
    Never seen any numerically lower thn that in a 14FF though. 14SF for that matter either.
  15. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I run 3.21 in the 14bFF in my Burb. Seems it shows up in bigblock trucks.
