Interesting Radio Question
Discussion in 'The Garage' started by Hossbaby50, Jun 6, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Today I was messing around pulling into the driveway. I shifted into 4Hi and my radio died. I thought I had blown the fuse again as I blew a couple fuses on the way back from Colorado. I would play CD's for a couple hours on a high power setting and it would heat up and after awhile blow a fuse.
    So I thought it was a fuse. But when I shifted it back to 2Hi my radio kicked back on. Then shifted back to 4hi and no radio. My truck will only run the radio in 2hi and shuts if off in 4x4 (hi or low).
    I am thinking it is some wiring behind the dash because my 4x4 and Low Range lights aren't coming on in the respective positions anymore either. Anyone had this problem or have a solution? Thanks
    Harley
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Sound's to me like, when You shift into low range, there is an open circuit, causing no light to come on, and no tune's, probe around with a test light, with the key in the run position, and the t-case, in low, and then in high. /forums/images/graemlins/eek.gif
  3. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    wires for the 4wd shift indicator run under the carpet and up to the IP...just some food for thought...on gm units when the tcc solenoid develops problems static will be heard in the radio..did you run some wires for the radio under the carpet??
    DW
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Actually, sounds like you have one of the rarest of rare K5's. Back in the day, GM was always thinking of new and crazy stuff and one thing they came up with was a safety feature. This safety feature was a switch that turned off the radio once the vehicle was put into 4wd. The people at GM thought that a person who had to use 4wd shouldn't be distracted by a radio.
    Anyway, GM didn't say anything to anyone, they just recorded the VIN numbers anytime the K5 came into the shop. Furthermore, if the owner brought the truck in with that exact complaint, the dealer would take the switch out w/o telling the owner, it was always "something else."
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    /forums/images/graemlins/thinking.gif
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Well I kinda doubt that. I have had the radio on many times when it was in 4x4. This is the first time it has ever happened. Wish that was my problem.
    Harley
  8. Grim-Reaper
    7,385
    Atlanta
    The wiring for the shift indicator runs under the carpet and up the fire wall. My bet is somebody tapped into the wire lookinf for power for the stereo instead of just pluging into one of the dozen or so open slots in the fuse box.
