Interference between cell phone and CB antennas
Discussion in 'Communication (CB | GPS | HAM)' started by driney, Feb 16, 2003.
  1. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I already have a roof mount cell phone antenna. I would like to add a roof mount CB antenna (no wires showing) but I did not want to create a problem with them being too close together. I will be running a fairly small antenna, and legal power on the CB. I don't need much range, just to talk to friends traveling with me.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I don't see a problem with it. Serously, are you going to be keying up the CB when you're on the cell phone ?????
  3. driney
    Jul 6, 2001
    699
    7
    I don't expect to use both at the same time other than the phone will be connected and turned on. I may try it with a magnetic mount before I start drilling holes. Thanks! /forums/images/graemlins/thumb.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You'll be fine. There is a huge frequency difference between CB's and cell phones.
  5. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    What about CBs and Radios? Cuz i got a Cobra and a 5ft ant.behind the cab mounted to the bed and if the radio is on its like i got the PA switched on cuz i come over the radio speakers. Im on the Radio /forums/images/graemlins/thumb.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    That has more to do with the wiring than the antenna's. That used to happen to me when I put an external amp on the radio. I ended up putting filters on everything and running the antenna wire different and it all cleared up.
  7. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    Yep, that's just RF interference. Get you a good noise filter on your AM/FM radio to help with that. Of course if your pushing a lot of power then it may not help much. I used to get some cell phones way back when they were in the 800 mhz range before the new digital ones. If your running a 102" steel whip they like to leak RF pretty bad.
  8. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    between frequency and modulation type youll be fine. with ur cell phoen beinge digital, it lil act like the analog RF form teh CB is interference and tuen it out.
