Interior brake light... It's driving me nuts.
Discussion in 'The Garage' started by mr.smartass, Jul 15, 2006.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    i installed a 4" inch suspension lift on my '89 k5 about 2 months ago and when i did i must have done something to trip the interior brake light... the wire on the proportioning valve is still plugged up and the parking brake is disengaged... i and i've bled the brake system and there is plenty of fluid in it... i don't know what else it could be but that red light won't turn off... please help
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    How does the peddle feel? What happens if you take the wire off of the proportioning valve? If that does nothing take the one off of the E brake switch and see if it goes off. When one of them makes it go off then you know which one is setting it off. Once you know that it should be easy to troubleshoot.
  3. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    had the same problem. The upper part of the brake pedal arm pushes in a switch when depressed. Check the wires to this. You probably have a bad ground at this point.
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    put black tape over the light.
    Just kidding!:eek1:
  5. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    could the e-brake cable be too tight and not letting it fully disengage
