Interior Door Panels
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LA Bogger, May 30, 2002.
  1. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    Has anybody had any problems with Coverlay or LMC interior door panels vs. OEM? Just checking before I start. Thanks for any info.. /forums/images/icons/smile.gif
    Eat More Mud!!!
  2. dyeager535
    26,982
    191
    I've never had problems, but if you look at LMC's catalog, last I checked, they had a little disclaimer that they weren't "exact" replacements or something. IMO, if you want the RIGHT part, go with GM. If you really aren't concerned with fit, finish, or quality, go aftermarket. Some times that matters, sometimes it doesn't.
    The way GM's replacement parts are going now though (made in Taiwan, etc) the fit, finish, and quality of even GM replacements are getting worse. STILL better than aftermarket in almost all cases though.
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I have a Coverlay dash and door panels, they have been installed for about 6 years with no problems. The only thing I noticed is, when they get hot (mine are black), they expland and warp a little, but when they cool down, they go back into shape....probably because they are made of ABS Plastic, but other than that, the fit and quality is good! /forums/images/icons/smile.gif
  4. ZfromNJ
    ZfromNJ Registered Member
    Jan 26, 2001
    99
    New Jersey
    I bought the door panels from LMc and they are not very good. My windows bounce around a lot.
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    So you can can door panels from GM? I thought they were discontinued. I'd love to get a PN for these if it exists.
    Sorry to break into your post Paul. I thought it might help everyone. /forums/images/icons/smile.gif
    John
  6. dyeager535
    26,982
    191
    *That* I'm not sure of...if anyone wants to check, post a part number for one (likely GM stocks only one color, one style, such as brown non PW, non PDL) and I can check. So could anyone else by going to www.gmpartsdirect.com
    I was thinking more along the lines of salvaging stock ones off of another truck, but GM is always the best option for brand new parts that fit like they should. I mean come on, aftermarket hasn't figured out how to mold plastic yet??
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    how does that affect your window? the interior panel has nothign todo with the windws.... ?unless after 77 they changed it....?
    grant
  8. dyeager535
    26,982
    191
    Well, at least '81-up, the inside of the window rides on the felt strip stapled to the top of the door panel. I'm surprised I haven't broken a window slamming mine without door panels, the window moves a good 1/4-1/2" or so without it, and CAN hit the metal of the door.
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    k, i see what you are saying. you are right.
    my bad.
    grant
  10. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    I checked with my local dealer for some 91 grey door panels. They wanted like 600 dollars EACH.
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    try Cheyenne pickup parts...someone may kow the web address, I don't htough. thye are supposed to be real good.
  12. ZfromNJ
    Jan 26, 2001
    99
    New Jersey
    THe door panels seem to be a lot looser then the original door panels were. They do not exactrly fit either. As stated before I didnt relize that they put that little disclaimer that the panels were not exact replicas.
  13. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Someone is jerking your chain hard. I haven't looked in a while but the last time I looked them up they were about $110.00 ea. I'll check and post back.
    Jim
  14. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Early models about 107.00 ea. Late models 78.00 bucks ea.
    Jim
