Interior Door Panels
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by cleszkie, Mar 6, 2003.
  1. cleszkie
    cleszkie 1/2 ton status
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    Is it a direct swap to use interior door panels from a 71 on my 72 K5? I know the 72 model uses plastic panels with plastic push fasteners, and that the 71 model uses metal panels with screws. What type of mounting hardware or mods am I looking at?
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I think they would line up but the 71 are diff looking then the 72, the 71's are flat were the 72's have a texture and thicker wall on the bottom...I can look in my books tonight..you can look through this
    http://truckandcarshop.com/
  3. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    '72 is a unique year....
    If you check the parts books you'll see that the window regulator is unique on the '72. I think that's because of the armrest/panel change and the fact that the window crank post needs to be longer to fit through the new panel.
    If you put a '71 panel on the '72 my guess is that the window crank will stick out farther than you're expecting and may look weird. I'll be curious to see a pic if you try it though.....I was planning on swapping in the '69/70 panels onto my '72. /forums/images/graemlins/laugh.gif
  4. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    As stated above, the 72 is a unique year. I have a 72 with stock door panels in good shape that I will be needing to get rid of here before long... I am replacing the 72 doors with 71 doors. I made some door panels for those from hardboard (not cardboard) cut into the right shape, 1/4" dense foam and marine vinyl... cost me about $15.00 per door... The 71's attach with a chrome strip at the top (slip in) and 4 bolts at the bottom. the 72's were more "modern" with the little plastic tabs along the edges and a couple little screws.
    -Ryan /forums/images/graemlins/k5.gif
