interior lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NYC K5, Dec 19, 2000.
  1. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    i have an 85 and was wondering if the interior lights should come on when i open the door. they come on when i turn the switch so i know its not the bulbs. what shoul i look at the door strikers? or something else?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    There is a button like thing on the front side down towards the bottom of the door opening, that may be broke or corrided.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes they should come on when you open the door. look at the pin in the door jam if it is sticking replace it they are a couple of dollars at the parts store
    s.smith 77blazer lookin 4 mud
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I just replaced both door jamb light switches around a month ago- nothing to it. Use a deep socket(7/16, I think) and back out the switch. It should be hooked to a single wire. If the switch is the problem, disconnect the wire, hook up the new one, and tighten it back in.
    One of my switches had a broken spring, and the other had simply become disconnected. I had to pull the disconnected wire through the hole with a 8" piece of 14GA wire bent into a hook at the end.
    One hint: Twist the switch 4 times COUNTERclockwise before you tighten it in. This helps to keep stress off the wire- the four turns it takes when you thread it into place leaves the wire without any twist in it.
  5. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Good idea CanmoreK5. Just a bit of information I found out when re-wiring my dash. The pin switches in the doors are just ground wires. The juice goes the the lights and then to the switches so when the door opens, the spring pushes the pin out and completes the circut.
    Fencepost eater
  6. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I took mine out and have not regreated it once
    when I was trying to work on my blazer the light being on all the time just got to me and that bizzing oh man is that anoying
    [​IMG]Go prepared
    http://www.trailblazer90.coloradok5.com
  7. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    james, you could install an override switch. i got the idea from my 96 sub. just a very small toggle switch, "off" and no lights come on, door open or not....."on" and the whole circuit works like normal. it helps not draining the battery when you just want to leave the doors open for no reason. also, this way i hooked up the tailgate to the ciruit too.
    Knife.
    knife.coloradok5.com
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    well my interior lights only work on my passenger door. which is fine by me. i dont like em to come on. dont know why but i just dont.
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  9. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    that cut-out reminds me of back when i had a ninja. i ran from the coppers on occassion, so i wired a switch into my brake lights, and another one into my taillight circuit, so i could disappear into the night. the brake light cut-out works nice when you have to slow down quickly because that cop just pulled in behind you.
    i know i probably won't be running from the man in my blazer, but it's another switch on my dash.
    a bit of useless information i found....
    if i turn the dimmer switch to the lowest setting (dash lights off, with the headlights on), the lights-on-with-key-out buzzer stops buzzing.
    <font color=purple>delta9blazer</font color=purple>
  10. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Nay Ideas, In my 91 K5 they do not come one when i open the door or when i turn the switch. It is not the bulb or the fuse. Any Ideas?
