Interior overhead lights not working...UPDATE...another question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Oct 7, 2004.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    A little while ago, my overhead interior lights, in the cab and hardtop quit working. However, one time they came on and I messed with the door jam switch, pushing it in and out and they continued to come on. The one under the dash burns like it should.
    I checked fuses but none are burnt out. Any thoughts?
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Re: Interior overhead lights not working...
    bad door jam switch? I replaced mine on the driver side because my interior lights would not work... /forums/images/graemlins/dunno.gif
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    That's kind of what I was thinking. I haven't looked it that yet, but how hard is that to get to. From just glancing at it, is there a nut or something that unscrees and you pull it out of the door jam?
  4. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    yeah, well you crank on that "nut" and the whole thing comes out.... Really easy to replace. I got my replacement switch from LMC... /forums/images/graemlins/grind.gif
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    real easy to replace. napa, advanced auto, most parts places have them. Only a couple bucks each.
  6. barryb
    barryb Registered Member
    Oct 15, 2003
    51
    Springfield MO
    pull it out and ground the wire to test your therory, if the lights work when wire is grounded - you nailed it.
  7. Can Can
    15,555
    151
    Cochrane, Alberta, Canada
    Here's a little hint when you go to replace the switch. Before you thread the new switch into the hole, twist the whole setup, wires and all, a couple of turns counter-clockwise. That way, when you thread it in clockwise, the wires end up in a prone(not twisted) position.
    Does that make sense? /forums/images/graemlins/crazy.gif
  8. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Ahh, good idea. I haven't been able to replace them yet. I'll have to let you guys know if they were bad or not.
    Thanks for the help /forums/images/graemlins/peace.gif
  9. bigred85
    bigred85 Registered Member
    Jul 12, 2004
    61
    Dallas, TX
    I remember a discussion about this a while back. When the switch is pushed in(door closed), does this open or close the circuit??
  10. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I'd take a peek at this too:
    Under the front carpet on the kick pannel. Where your feet are while driving, there is a white and an orange wire. The orange wire get's all gangenous and nasty, and eventually stops it from working.
    GMC Gremlin
  11. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Re: Interior overhead lights not working...UPDATE....another question
    So I replaced both of the door jab switches and still no overhead interior lights. Here's the kicker, the driver side had two wires pugging into the door jam switch. The passenger side only had one white wire that was plugged into the door jam switch. I fished around looking for the orange wire like the driver side had but found nothing.
    The driver side has the two wires go through the door jam in the same place but over on the passenger side the white wire is the only wire that goes through the door jam.
    Im stumped, what about you guys?
  12. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    There should be only one wire on the passenger side and two on the drivers side. You know that the switches ground out through their threads. So if the threads are painted or rusted maybe that is why you aren't fixing this. Are the wires F'd under the carpet somewhere?
    -Chris
  13. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I didn't get the chance to see what kind of condition the wires are in under the carpet. I will look at that next. Also under the dash, the orange wire seems to go upward and into the general direction of the headlight switch, didn't investigate it too much due to time constraints. Maybe the portion of the headlight switch the overhead lights plug into is fubared?
  14. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    The orange wire will run to the headlight switch. That allows you to turn on the interior lights with that switch.
  15. sickquad
    Jul 23, 2003
    785
    Ma
    My interior lights turn on when I open my doors but I cannot turn them on by turning the headlight switch. So that orange wire probably is not your problem.
