Interior panels
Discussion in 'The Garage' started by elwhitey, Oct 8, 2005.
  1. elwhitey
    elwhitey Registered Member
    Mar 21, 2005
    42
    Chandler, Az.
    I have just pulled out the vinyl side panels out of the bed of my '74 Jimmy. I am applying herculiner in the morning and would prefer to replace the vinyl with sheetmetal that I can herculine as well. Does anyone offer these as a prefab or will have to have these cut to spec?
  2. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    alot of people use wood paneling or diamond plate alum or steel but im sure you have to cut it out yourself just remember if you use alum or steel to put a dab of silicone on the mounts so it dont squeek/rattle
    balzer
  3. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    What's the easiest method to cut sheetmetal to fit?
  4. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    make a cardboard template, or use the old sides to trace an outline on the sheetmetal, and then plasma cut it out. Thats the easy way.
  5. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Thanks. I'll see if I can get ahold of a plasma cutter when I finally get to this part. I wasn't sure what I was going to do.
  6. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Heck, I'd just make them out of some 1/4" plywood. It's cheaper, and you can still line it too. Not to mention it can be cut with something as common as a jigsaw. Plus, once it's lined, it would be easier to make any new holes that you might need .. like for speakers or whatever. I would think the plasma would not leand itself too well, to cutting new holes, once the liner is on. Just make sure you line the edges good, and probably an inch or so overlap onto the backside (at least the bottom) to resist any water absorbtion that may get in if the top is off.
  7. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I just did my rear floor with 3/16 aluminum and I a jig saw to cut out the wheel wells. It worked good but took some time. I would only use 1/8th for the side though. It will be much easier to cut to. Just get a sheet metal shop to cut you a piece the right length and witdh and then alls you will have to do is cut out the wheel wells and around the tailgate latch.
  8. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    And drill for the seatbelts/shoulder belts, if you're still running stock belts. Oh, and cut the little hump for the gas filler neck. LOL :p:
  9. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
  10. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    I just left mine out, and thought a lot of others did as well. I have my hi-lift and shovel mounted on the sides and i enjoy the advantage of having just that much more room!
