interior:removing tar gunk from under carpet
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Apr 30, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Anyone have a suggestion as to simple ways to do this?
    Ken H.
  2. racercrazy
    racercrazy 1/2 ton status
    Dec 29, 2001
    145
    O\' Fallon, MO 63366
    Wirewheel in a drill gun.
  3. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    I used a rust wheel from 3M, it leaves less gouging than the wire wheel, and a bernzomatic torch and a putty knife.
    They both worked very well.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    On my 84K5 it came up really easy. I used a dull putty knife to scrap the stubburn stuff up. Worked pretty good.
  5. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I believe General Motors got this stuff from aliens.
    The worst places for it is on top of the wheel wells. I have hacked and scraped this junk off of 2 of my previous trucks and it is really a nasty job.
    While I was removing the carpet from my Suburban last weekend my wife came up with a great idea. She ran inside and got a couple of heating pads (those of us who are "a little past our prime" have many of these lying around). I turned the pads on HIGH and placed them on top of the wheel wells for about 15 minutes. Once they got everything nice and warm I grabbed a corner of the carpet and peeled it right off! There was only a little bit still stuck on the wheel wells that came right off with a putty knife.
    I'm sure that you could use other methods but the idea is to get the stuff warm so it is flexible. Next time I have to do this I may try to heat it up from the outside with a heat gun. That might be a little quicker.
    No hacking, scraping, cutting, grinding or swearing.
    Hope it works for you too!
  6. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Use the 3m rust wheel ;-) It looks like a plactis honeycomb material. Also get many rags and some acetone, nut keep the acetone off you skin or it will be supper dry. I use the acetone daily here and I think I have become imune to it, but it sure lets you know when you have a cut ;-( ouch that burns
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    We have run into tar all the time in OHIO, try using a Burnsamatic torch or heat gun to heat up the surface (be carefull) then scrape with a putty knife. It will scrape off like butter.
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i put a wire wheel in a grinder.
    but when you do this, make sure its shooting the stuff out the rear, otherwise it till be ALL OVER everything
    took me like less than 1 hr to do both of em and didnt hurts the wheel wells
    i hurculined over it
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    when i did my herculiner project I ran into that crap. Nasty stuff... I agree that it might be extraterrestrial. /forums/images/icons/tongue.gif
    At any rate, a combination of a drill-mounted wire brush, putty knives, xylene, and flat screw drivers (for REALLY nasty clumps that refuse all other means of removal!!!) got the job done. Few things have made me wish that I had some sort of portable sand blasting device... /forums/images/icons/wink.gif
    J
  10. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Heat gun or a hair dryer worked well for me.... when it was warm it was plyable and peeled up fairly easy. The wheel wells were awful, I used a good putty knife then. I didn't want to wire off the paint on the floor if I didn't have too....
