Intermittant/Flaky fan operation
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by MikeH, Feb 21, 2003.
  1. MikeH
    MikeH Registered Member
    Apr 5, 2001
    24
    Monument, CO. USA
    Hello;
    Recently the fan on my '71 (w/AC) quit on me. But intermittantly it comes back on and works fine then will cut out again. Usually comes back on after driving for awhile.
    Probably a short somewhere, i will check that out. just wondering if this has happened to anyone else.. Thanks
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    When I pulled the heater fan (don't have AC) the squirrel cage had been stuck in place and the motor continued to spin (well, for a while anyway). The center of the squirrel cage had melted away. It appeared that all the extra resistance killed the motor. The previous owner used a piece of tin foil over the fuse so the heater motor would keep running and not blow the fuse - brilliant!
    Most likely a short, but check to see if anything is physically stopping the motor too.
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Check the blower resistor first, then the switch in the control panel. The motors rarely go bad (but it does happen).
  4. MikeH
    Apr 5, 2001
    24
    Monument, CO. USA
    Thanks guys, I will check it your suggestions...
    MikeH
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Bad switch.
