Intermittent Fuel Problems?
Discussion in 'The Garage' started by bpiccioni, Oct 9, 2003.
  1. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    Vehicle:
    87 3/4T 4x4 /forums/images/graemlins/burb.gif 350TBI 4.10 TH400/208/14BSF/GM10B/MSD 6A
    Problem:
    When I make right hand turns onto my local highway, which usually involves a good deal of gas and a short, steep climb from a parking lot to the raised bed of the highway, I experience a noticable loss in power and acceleration.
    After several seconds, this problem goes away and the motor roars back to life. It almost seems like a stutter you get when the gas is runnign really low, or a bog when you stomp a poorly adjusted, carbed vehicle's accelerator.
    The only thing I could surmise is that I might have some problem with either an electronic device that wants to turn the fuel off, like an emergency sensor, or a bad connection somewhere to the fuel pump, like a wire that gets pinched when I make right turns uphill or something.
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Do you filler up with gas or keep it below 1/4 tank?
  3. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    I fill up w/ regular every time I go to the station - about 300+/- miles on my odometer. I have noticed the problem at all different tank levels, so I'm pretty sure it's not a pickup problem. However, my glovebox says I have a 31 gallon tank, although the rig can only seem to go at most 28 Gallons before it starts dying.
  4. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    have you checked the fuel filter? Might be a good place to start and a pretty cheap fix. Probably should be changed anyways if you've never done it
  5. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    Yah, I swapped it out with one the previous owner had left in the center console not too long ago - maybe as early as this past spring? Im not sure what brand it was (Carquest?), but it was new in the box.
    I am pretty sure the problem existed before the fuel filter swap and still persists, but another fuel filter isnt too much $$$ just to be sure. Is there a 'GOOD' fuel filter I should consider?
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    maybe the baffle in your tank broken loose floatin around?
  7. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    Is there an easy way to check for this without dropping the tank?
  8. dyeager535
    26,979
    Nope. Only clue I can think that it may give you, is problems with the fuel gauge readings sometimes...if the baffle is moving around, it may interfere with the float.
