intermittent wipers?
Discussion in 'The Garage' started by carolina k-5, Mar 30, 2005.
  1. carolina k-5
    carolina k-5 Registered Member
    Jan 20, 2005
    58
    columbia, S.C.
    my 77's wiper control options right now are off, low, high. what would it take to make them intermittent? just change the dash mount control? or would i have to swap the motor etc? welcome to south carolina, if you dont like the weather wait a couple hours.
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    I would like to know the same thing... TTT
  3. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    You would need to swap the switch and also the under dash module. Motor is the same
  4. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Parts to be had at any local 'yard with a chevy in the lot eh?
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The problem with using the factory pieces (something like 78-82ish) isn't that they will swap right in - they will- its that the brain box has a very high failure rate. When I was searching all the local junk yards for the required pieces I found a ton of the switches, but only 1 box. It was enough to convince me. I found an aftermarket control box/switch and went that route (but those too are hard to find). I couldn't find a commercial producer of the "kits" to convert to delay, one of the junk yards had a "new" unopened one from the 80's that I bought-works great.
  6. carolina k-5
    Jan 20, 2005
    58
    columbia, S.C.
    brain box? wheres that located on my truck?
  7. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    It should be located under the steering column , under the dash.
    It kind of looks like a small amp. for lack of a better description :grin:
  8. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    this post has kind of helped me, i've been bench testing and testing my wiper motor, hooked up the ground to the spot that it normally grounds out to the frame. actualy i tried a few grounds and a few power options, nothing made the motor turn over. do i need the "brain" to even just test my motor? Can i buy just the brain at a parts place? have the "off, low high" switch still, just not the brain between the switch and the motor
  9. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    i just got my new lmc catalogue today, and i flipped through it real quick and notice a kit to convert your non intermintent wipers to intermintent. if i recall corectly iy was under $60 bucks for everything.....
    just a thought..
  10. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    If any of you guys have the '89 setup, I've got the control box for one - I don't need it.
