Internal hubs on an external hub spindle???
Discussion in 'The Garage' started by BamBamblazer, Mar 1, 2004.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    Ok i have a d44 that has external hubs, so i pulled the hubs to switch to internal and the spindle looks the same? I slid the internal hub on the external spindle and it seems right? I had read somewhere that you can't do this. Am i missing something here or will the internal hubs work on an external spindle??????
  2. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    You can, as long as you put a small bearing hub on your small bearing spindle. IE, the external lockouts on dana 44's were early '70's. These are also the spindles/flat top knuckles people search for to use ford 5 on 5.5 hubs with. Not sure if Chevy offered an 8 bolt hub with a small inner wheel bearing, you might have to see if a ford one will work assuming you're running 8 bolt. Otherwise, trade your small spindles to me for some big bearing spindles and be able to run later model internal 8 bolt hubs.
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    My understanding is that the spindles are the same. I have a friend that once told me he used a 6 lug 10 bolt spindle on a 8 lug (ext type) D44.
  4. BamBamblazer
    Jun 24, 2002
    486
    Well i guess it will work, i just ran (ok i walked) outside and tried to put the external hubs in the internal spindles and they slid right on. Now correct me if i am wrong but if one is smaller it will not fit on the larger spindle. So since they both slid on ok i guess i got lucky and they will work! /forums/images/graemlins/thumb.gif
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Here is a pic showing the smaller spindle vs. the bigger. The differences are obvious. /forums/images/graemlins/waytogo.gif
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I did 4 years ago...
