Internal or external?????
Discussion in 'The Garage' started by BamBamblazer, Feb 26, 2004.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    I am getting ready to do the axle swap on my k5 and dont know what to do. I have 2 different d44's One is an early 44 with flattop's and external hubs as well as the gears im gunna run. The other is a internal hub's with no flattops and the wrong gears. So should i swap the internal hub's to the flattop axle or just run the bigger external hubs?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i would run the bigger hubs, it seems to me that the hubs are stronger, but also more expencive. /forums/images/graemlins/dunno.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Run the internal hubs on the flat tops. The external hubs are a weaker design than the internals. The spindles and bearings are smaller than the internal design hubs. Lockout hubs are also cheaper for the internals. /forums/images/graemlins/waytogo.gif
  4. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I would put the internals on the flat top axle. I have seen alot of heep's that have externals and are blowing them. So with the weight of a full size I would go with the internals all the way.
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    like everyone else is recomending, go with the flat tops and internal hubs.
    to keep my opinons rolling, i highly do not recomend the warn replacment external hubs, they plain out suck. and the OEM spicers had a poorly designed plastic cap that was very well known for leaving you stranded.
