Intresting Info about aftermarket chips
Discussion in 'The Injection Section' started by 1979jimmy350, Sep 21, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    Ann Arbor Mi
    I was just comparing a stock TPI chip to a Stage one Chip and i was pretty suprised. Using a compare function on tunerpro there was only one difference betwwen the two bin's. The only thing that was different was the spak table. The table was advanced by a few degrees across the entire table!
  2. dyeager535
    Yep, typical of aftermarket "generic" chips. Companies have been doing this since the computer controlled carb days. Those chips do exactly what they are supposed to: take the money out of your pocket and put it in theirs. :)
    Sometimes you'll also see differences based on the lower temp thermostats commonly required after one of these chips, since advanced timing tends to lead to problems.
