irock's or tsl's
Discussion in 'The Garage' started by chebbykrawler, Oct 13, 2005.
  1. chebbykrawler
    chebbykrawler Registered Member
    Feb 6, 2005
    10
    nevada
    I am lookling into buying a new set of tires for my 87 chevy blazer, i am currently running 35-1450-15's with a 4 inch lift and cut fenders, was wonatin to go a little bigger, i have two choice
    irok 37-14-15's
    tsl 38.5-16-15's
    does anyone runn the iroks and how do they perform in the rocks as well as the mud.
    what would you guys recomend the tsl's or the irok's
    any help appreciated
  2. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I have the same issue but I decided to go with the IROK's. I want 36 IROK's Bias ply, no real reason but they are cool. TSL's are looking pretty good with their old school style and all, but the IROK's are also looking pretty cheap (relatively) and a lot of vendor's have my size.
  3. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    I have grooved TSL's (44's), and am neither satisfied nor dissatisfied with them. I'd like to switch over to 42" Iroks, mostly just to try something new. Go with the Iroks, if for no other reason, they'll be a few dollars cheaper, comparatively speaking, and they seem to be the best of all worlds.
  4. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I was thinking TSL's just cause I drive on the street a bit. Don't the IROK's wear faster?
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have ran both tsl's and iroks and i like the iroks way better. they ride smoother they are quieter. and do every bit as good in the mud if not better then the tsl's did. im sure you would like the iroks better also :D :D
  6. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    They would wear about the same.... You'd be hard pressed to get more then 10,000 street driven miles on either tire.
  7. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    their are radial versions of both, you may want to consider looking in to those.
  8. TX_GLADIATOR
    TX_GLADIATOR Registered Member
    Sep 21, 2005
    60
    San Antonio TX
    44
    i just put a set of 44 TSL's and went out last weekend & very impresed TSL's for me or 47'' LTB's :D
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    Iroks are good and sticky and have a nifty high tech tread design that really grips. They also have thin-from-the-factory tread depth and relatively short life expectancy due to that high void tread.
    TSLs are basically the opposite... old school tread (time proven!), deeper tread depth and they will live (relatively) longer.
    Personally, it comes down to a cost issue. If I could afford to buy new sets of Iroks all the time, I'd run them. I'm poor and can't though, so I'd rather stick with TSLs.
    j
  10. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    There is only .093" differance between 42" bias IROKs and TSLs.I cant say that would ever sway me one way or the other on a tire choice :D
    I have 42-14-16.5 bias IROKs.I got them cuz they stick like glue on the rocks.
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I have seen 2 trucks with about the same setup try a obstacle, one had 42" TSL's the other had 39.5" iroks, irok truck walked right up. I was sold at that point.
    I am currently saving up for iroks in the 42" variety.
    Ow this was in the rocks by the way, dont do much mud here.
    Also iroks are alot light then a TSL.
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    39.5's yes, 42's no
